Main Forums
Car Talk
Car Modification
Brakes!
<blockquote data-quote="SkYwAlKeR" data-source="post: 3321603" data-attributes="member: 10341"><p>disc and calipers are mostly the same... the only thing u need to upgrade is ur brake pad... racing brake pad works wonderfully at high temp, but low temp doesnt bite well... normal brake pads work well at low temp... but once they gets heated up, u will have brake fade...</p><p></p><p>if ur oem disc/rotor is solid disc, i recommend u to get ventilated disc at least... it allows better cooling as heat is the main factor for a brake to fail... cross-drilled is not necessary unless u feel it is needed... because cross-drilled rotors accelerate ur brake pad wear n tear.... it also causes lots of stress to ur brake disc, which might crack ur disc....</p></blockquote><p></p>
[QUOTE="SkYwAlKeR, post: 3321603, member: 10341"] disc and calipers are mostly the same... the only thing u need to upgrade is ur brake pad... racing brake pad works wonderfully at high temp, but low temp doesnt bite well... normal brake pads work well at low temp... but once they gets heated up, u will have brake fade... if ur oem disc/rotor is solid disc, i recommend u to get ventilated disc at least... it allows better cooling as heat is the main factor for a brake to fail... cross-drilled is not necessary unless u feel it is needed... because cross-drilled rotors accelerate ur brake pad wear n tear.... it also causes lots of stress to ur brake disc, which might crack ur disc.... [/QUOTE]
Advan GT Beyond 19 Civic Type R FK8 FL5 Rim Wheel
TE37 Saga S Plus 18 Civic Type R FL5 FK8
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
PROTON Says DRB-HICOM Not Selling Lotus!
PROTON has just reiterated that their new holding company - DRB-HICOM Bhd, will not be selling Lotus, which is a...
Boost meters...and others
hi guyz.. jz wanna ask for ur opinions.. erm.. wuts da meters for? i c some cars they have all those meters..like dem ganas like dat.... im driving a stock wira with air filter, downpipe n stuff... can i install the...
external wastegate which sounds more ferocious?
guys...can u help me with the different external wastegates in the market like the HKS,Sard, Tial or etc
which one of them sounds different or more ferocious like u can hear them a mile away...
and how does the...
Main Forums
Car Talk
Car Modification
Brakes!
