Main Forums
Car Talk
Brake Pad?
<blockquote data-quote="tajulsans" data-source="post: 887736" data-attributes="member: 4192"><p>I would not say that its due to rotor abit warped, if warped than u will feel brake juddering liau.. its more like surface to surface matching.. even when both are new and 100% flat, still need to be match to one another.. </p><p></p><p>ive read some where that breaking in is by gradually increasing the disc temperature to its optimum, doing it by going to speed like 100kmh and apply constant pressure on the brake.. do it like 5 times in arow.. the purpose is to heat up the bonding material in pad material itself, by evaporating it and remove gasses and all so that the pad material will bond and perform at its best.</p></blockquote><p></p>
[QUOTE="tajulsans, post: 887736, member: 4192"] I would not say that its due to rotor abit warped, if warped than u will feel brake juddering liau.. its more like surface to surface matching.. even when both are new and 100% flat, still need to be match to one another.. ive read some where that breaking in is by gradually increasing the disc temperature to its optimum, doing it by going to speed like 100kmh and apply constant pressure on the brake.. do it like 5 times in arow.. the purpose is to heat up the bonding material in pad material itself, by evaporating it and remove gasses and all so that the pad material will bond and perform at its best. [/QUOTE]
R35 Used Titanium Exhaust
Penang Convoy 20th July - 22nd July
Convoy to penang 20th July - 22nd July.
RM250nett per room (without breafast) in a 5 star hotel in Penang. Parking is Good!
register and payment asap to Johnny:
Confirm
1.Leslie
2.Johnny
3.Alfred
4.Marzuki
5.Foo...
Diy Lowerd Spring,need Help
need advise and help bout how to change the suspension spring.from standart to sport. HOw to change it.Im driving a kancil belalang. Arleady bought the springs,just wana change it
what about if i do front sport rear...
Hidden ignition Starter Interrupter
http://www.the12volt.com/relays/page2.asp
Does anyone know how to fix this stuff in the car?
This will act like a imobilizer..
Main Forums
Car Talk
Brake Pad?
