Main Forums
General Talk
Brake Fluid
<blockquote data-quote="neo_geo" data-source="post: 4055500" data-attributes="member: 80425"><p>higher the dot higher the boiling point.. because stoppage of movement transforms kinetik energy into thermal energy (first law of thermodynamics) the high temperature can more than often boil the brake fluid in the lines.. unlike fluid, air can be compressed... therefore u need to depress the brakes more.. </p><p></p><p>another form of brake fads happends when the heat between the disc brakes and brake pads form a thin layer of gas in between which hinders contact path. this also makes braking inifficient..</p><p></p><p>and try not use brake fluids which has been exposed in the open for too long or has expired from its shelf life date.. brake fluids exposed to the atmosphere absorbs water and this form of water boils even faster in ur line...</p></blockquote><p></p>
[QUOTE="neo_geo, post: 4055500, member: 80425"] higher the dot higher the boiling point.. because stoppage of movement transforms kinetik energy into thermal energy (first law of thermodynamics) the high temperature can more than often boil the brake fluid in the lines.. unlike fluid, air can be compressed... therefore u need to depress the brakes more.. another form of brake fads happends when the heat between the disc brakes and brake pads form a thin layer of gas in between which hinders contact path. this also makes braking inifficient.. and try not use brake fluids which has been exposed in the open for too long or has expired from its shelf life date.. brake fluids exposed to the atmosphere absorbs water and this form of water boils even faster in ur line... [/QUOTE]
My tyre has some damage, is it still ok to use? (picture in thread)
A while ago while driving on the highway, I hit something. At that time, I thought it was just a small rock or something, so I just continue driving. Just now when I checked my rear left tyre, there is a small piece...
Part 1: Tokyo Auto Salon 2008
Finally, over 300 days have...
Year End Gathering - We are on Autoparts & ExtremeKars Magazine this month
Dear All,
The year end gathering 2006 was a great success and we are now being featured in Autoparts and Extreme Kars magazine this month. Do check it out!!!
It was a great effort.
Thanks again for turning up and...
Main Forums
General Talk
Brake Fluid
