Main Forums
Car Talk
Brake failure
<blockquote data-quote="Izso" data-source="post: 1064374509" data-attributes="member: 2429"><p>How old is your car gothculture? Check for leaks at your brake hoses. If you're still on the OEM rubber hoses they will crack and wear out after many years. If you're on steel braided make sure they stay clean cuz dust and rocks will kill it. Either way check for leaks. </p><p></p><p>If you're really unlucky like me, the oil seal in the caliper might be leaky and that is impossible to replace cuz no one sells this part. Have to change the whole caliper or test different o-rings to see if they will do the trick</p></blockquote><p></p>
[QUOTE="Izso, post: 1064374509, member: 2429"] How old is your car gothculture? Check for leaks at your brake hoses. If you're still on the OEM rubber hoses they will crack and wear out after many years. If you're on steel braided make sure they stay clean cuz dust and rocks will kill it. Either way check for leaks. If you're really unlucky like me, the oil seal in the caliper might be leaky and that is impossible to replace cuz no one sells this part. Have to change the whole caliper or test different o-rings to see if they will do the trick [/QUOTE]
Mazda RX-7 gets sideways with a Ninja ZX10
It’s one of those scenarios that you always wondered about but never really got the chance to see played out. Sure cars going sideways are a thing of art but even their two-wheeled counterparts can get that back end...
2009 Nissan GT-R V-Spec Scooped?
Just when you think there’s nothing more to see or read about Nissan’s GT-R super-coupe, images of a mysterious prototype start to crop up on...
Skyline GT-T Bumper Signal Light
hi there
i'm looking for skyline gt-t bumper signal light
i will appreciate if anybody here can let me know where to get it
thanx
Main Forums
Car Talk
Brake failure
