Main Forums
Car Talk
Forced Induction & Engine Management
Boost suddenly declined
<blockquote data-quote="stroker_kit" data-source="post: 207104" data-attributes="member: 1595"><p>if thats the case, then there could only be a few reasons...</p><p></p><p>1. leakage on intercoller piping</p><p>2. blowoff worn out</p><p>3. wastegate/actuator worn out</p><p>4. u boost controller tak cun, specially if u use those cheap aquarium valves.....</p><p></p><p>worst is ur turbine housing leaks, but this dont usually happen, unless u run a very hi boost where ur turbine cannot tahan.... sometimes the fin of ur turbine could also be the cause.... one case ive seen where the fin hits the compressor wall cos the fin shaft loose a bit. the grinding effect made the fin smaller and the compressor housing bigger, thus reducing the boost generated.... check ur fin as well. make sure there's only a little space between the edge of the housing and fin...</p></blockquote><p></p>
[QUOTE="stroker_kit, post: 207104, member: 1595"] if thats the case, then there could only be a few reasons... 1. leakage on intercoller piping 2. blowoff worn out 3. wastegate/actuator worn out 4. u boost controller tak cun, specially if u use those cheap aquarium valves..... worst is ur turbine housing leaks, but this dont usually happen, unless u run a very hi boost where ur turbine cannot tahan.... sometimes the fin of ur turbine could also be the cause.... one case ive seen where the fin hits the compressor wall cos the fin shaft loose a bit. the grinding effect made the fin smaller and the compressor housing bigger, thus reducing the boost generated.... check ur fin as well. make sure there's only a little space between the edge of the housing and fin... [/QUOTE]
R35 Used Titanium Exhaust
Sharing xperiance..Pivot 3-Drive
hi all...
just wanna ask for z33 owners who have xperiance using this stuff...Pivot 3-Drive Throttle Controller...
i just install it to my z33 at Kl Auto Jln Ipoh...got 3 mode...Economic..Normal...and Sport...for...
FAQ: Forced Induction
Here are some productive and informative pages for forced induction , feel free to add more
Forced Induction
Supercharger
http://www.zerotohundred.com/newforums/showthread.php?t=4389...
MR2 CARicatures
If any of you would like your precious MR2 to be 'car-icatured' please post ur car pix in the MR2 gallery! Cheers...
Main Forums
Car Talk
