Main Forums
Car Talk
Forced Induction & Engine Management
Boost Problem? Misfiring?
<blockquote data-quote="MRMIC2" data-source="post: 131341" data-attributes="member: 2637"><p>Hello acidburn,we meet again...</p><p>First check your ECU whether it is a stock ECU?For your engine should be red toyota label.It is located in your boot covered by carpet.</p><p>For the 1st/2nd Gen MR2 engine..The stock fuel pump,fuel regulator and injectors should easily take care of its fuelling below 1.1 bar boost.(430cc Sidefiring injectors)</p><p></p><p>Check your Blowoff valve spring tension...make sure it is tighten as too loose will cause boost loss.</p><p></p><p>As you have just installed the Supra fuel pump, installing a fuel pressure regulator gives you more control over the new fuel pressure.</p><p>What are your SAFC settings?pls elaborate...</p><p></p><p>The AVC-R shouldnt cause u any probs.</p><p></p><p>Check for loose/leaking vacuum hoses too.</p><p></p><p>Are your spark plugs the right heat range?</p><p>Check spark plug cables resistance if it snapped internally.</p><p></p><p></p><p>if all ok...then go for dyno to tune your afc.</p><p></p><p>Hope this helps</p></blockquote><p></p>
[QUOTE="MRMIC2, post: 131341, member: 2637"] Hello acidburn,we meet again... First check your ECU whether it is a stock ECU?For your engine should be red toyota label.It is located in your boot covered by carpet. For the 1st/2nd Gen MR2 engine..The stock fuel pump,fuel regulator and injectors should easily take care of its fuelling below 1.1 bar boost.(430cc Sidefiring injectors) Check your Blowoff valve spring tension...make sure it is tighten as too loose will cause boost loss. As you have just installed the Supra fuel pump, installing a fuel pressure regulator gives you more control over the new fuel pressure. What are your SAFC settings?pls elaborate... The AVC-R shouldnt cause u any probs. Check for loose/leaking vacuum hoses too. Are your spark plugs the right heat range? Check spark plug cables resistance if it snapped internally. if all ok...then go for dyno to tune your afc. Hope this helps [/QUOTE]
R35 Used Titanium Exhaust
New 2016 Merc CLA now in town, 3 guises and improved aero! - prices from RM234k
Featuring refreshed exterior styling and upgraded interior, the new CLA comes in 3 variants, namely the CLA 200, CLA 250 Sport and the high performance AMG CLA 45. The new 4-door coupe is priced from RM234k all the...
Pls Advise - PFC L-Jetro Version.
Hi Sifu's,
is there any additional gadget to convert L-Jetro from AF sensor to Map sensor?
Thanks
My Rx8 Was Robbed By Parang Wielding Robbers In Broad Daylight
MY RX8 WAS ROBBED BY PARANG WIELDING ROBBERS IN BROAD DAYLIGHT INSIDE MY OWN HOUSE COMPOUND!!!!
It happened at 6:30pm today, where 2 armed robbers (chinese) stormed into the house and held a parang to my maid's neck...
Main Forums
Car Talk
