Boost Controller
Boost Controller
cheechain
D2 Boost controller from USA. Dual stage Boost controller with Rocket launch/trigger given. You can get it at lowest price RM420. Installation can be provided at lowest rate of RM480 (plus installation). Negotiable if buy more than one items.
SMS or call me at 0193185319
Features:
- Complete plug and play kit no need annoying electrical connections!
- Full electronic boost controller, generates adjustable duty cycle to a high quality solenoid valve.
- Missile switch with power on led light.
- Easy installation just plug and play or connect Ignition+ and-.
- Adjust your boost level from the driver's seat.
- Small components will fit in neatly.
- Dual selection between set boost level and stock boost level.
This is a professionally designed full electronic boost controller, not like the other imitations is just a solenoid switch. This d2power electronic boost controller allow you actually adjust your boost level from the driver's seat and select between your preset boost and stock boost. No need to get under your bonnet to set your boost level!
Suit any turbocharged car you can install this controller within 10mins, then you will have all your freedom to adjust your desired boost level while you drive.
It also come with a adjustment label for easy dial adjustment!
RM420... Juct control the Boost from inside. Sold many items alreday and no complaint so far.
Chain 0193185319
