Main Forums
Car Talk
Forced Induction & Engine Management
Bleed Or Block...?
<blockquote data-quote="kschu" data-source="post: 156629" data-attributes="member: 2987"><p>y dun try a spring to pull d actuator to open longer than usual?then d boost will raise bt it's depend on how hard ur spring pull d actuator rod.......</p><p>if u wan more garang, do custom wastepipe lah........sure got sharrrrrrrrrrrrr...</p><p>hehehe</p></blockquote><p></p>
[QUOTE="kschu, post: 156629, member: 2987"] y dun try a spring to pull d actuator to open longer than usual?then d boost will raise bt it's depend on how hard ur spring pull d actuator rod....... if u wan more garang, do custom wastepipe lah........sure got sharrrrrrrrrrrrr... hehehe [/QUOTE]
R35 Used Titanium Exhaust
Toyota Malaysia is taking its motorsport presence to the next level. UMW Toyota Motor (UMWT) recently announced the...
Quantum high performance Adjustable Suspension kit
sold.......thank
£375,000 for Number Plate
It's eye-catching, well-designed and worth £500,000.
No, not the car ... the number plate. Businessman...
Main Forums
Car Talk
Bleed Or Block...?
