Car Brands
Car Manufacturers
Proton
Better plugs for Kenari?
<blockquote data-quote="butthead" data-source="post: 992669" data-attributes="member: 4408"><p>ehh...wat's ur badget??? can go from cheaper ones like Denso RM40 to Volker RM50++ then HKS, Apexi RM80++...wat u think???all price is in per piece...</p><p></p><p>turbocharging will have several factors to consider which plug you should choose...how much preassure you running??? your compression ratio??? fueling, A/F Ratio??? all these can contribute to getting a good spark plug..because force induction would generate more heat than normally aspirated...it is better to get a colder plug to transfer out the heat of the combustion chamber...i think your main concern should not be on performance first...rather on you can get the correct plugs or not...if you get the wrong plugs you might end up pre-igniting your mixture or the plugs might jus die covered in carbon...</p></blockquote><p></p>
[QUOTE="butthead, post: 992669, member: 4408"] ehh...wat's ur badget??? can go from cheaper ones like Denso RM40 to Volker RM50++ then HKS, Apexi RM80++...wat u think???all price is in per piece... turbocharging will have several factors to consider which plug you should choose...how much preassure you running??? your compression ratio??? fueling, A/F Ratio??? all these can contribute to getting a good spark plug..because force induction would generate more heat than normally aspirated...it is better to get a colder plug to transfer out the heat of the combustion chamber...i think your main concern should not be on performance first...rather on you can get the correct plugs or not...if you get the wrong plugs you might end up pre-igniting your mixture or the plugs might jus die covered in carbon... [/QUOTE]
david tao
Need help identifying these tail lights brand / manufacturer
Hey guys, i'm hoping to change my tail lamps and trunk lights for some LED goodness just for aesthetic purpose.
Any idea who manufactures these LED tails? I realized they are very different from what Spyder...
Introducing: Eagle F1 Directional 5 tyre by Goodyear - The driving enthusiasts' tyre?
Here's a new tyre that will give even the best tyres on the market a run for their money. According to Goodyear, it is...
DIY Starter Interupter
Found this on the net, planning to diy this starter interupter that consist of relay and a few wiring. Need info on you guys, to do it or not to do it, coz my cars don't have any immobilizer mar... Well here is the...
Car Brands
Car Manufacturers
Proton
