BC Racing Suspension Kit
SuperVelocity
5,000 RPM
BC RACING SUSPENSION KIT
BR Series Street and Circuit Coilover (High Low Soft Hard)
- Pillowball upper mount
- Camber adjustable top mounts
- Aluminium top plates
- 30 way adjustable damping
- Adjustable spring platform
- Height adjustment via bottom mount to retain full damper travel
- Bearing mounted upper front spring platform
- Dust boot to protect damper seals
The BR series coilovers use a large 46mm diameter piston in a 53mm diameter damper body to maximise oil capacity.
As the damper unit operates the oil contained within heats up. The viscosity of oil changes as its temperature varies which can lead to changes in the damping characteristic of the unit.
BC Racing only use a very high quality oil with their coilovers but go that extra mile to maximize performance and build their BR range with a large 53mm diameter damper body. This increases the capacity of the unit which increases the volume of oil contained which in turn reduces the peak temperature and so significantly improves damper performance.
- Suitable for most cars
- Interested please PM me for best price
- COD and Postage is available
what series of BC suit impreza version 9 114.3
want super hard like tein monoflex not tein superstreet.
Pm me the price for satria gti. Complete with pillow ball..thank,
boss, do pm for wira 1.8 cost....thx!!!
