Main Forums
Interests
Do-It-Yourself Garage
battery kill switch ?
<blockquote data-quote="eyong" data-source="post: 3626388" data-attributes="member: 23540"><p>I have used one of them before ... The FIA type (they are 300-500 ringgit) not your regular from Brothers or something. Basically it has two main poles, one on each sides for your battery cable. Then in-between the two main poles, are four slot-pins; a pair for fuel-pump; and another pair for ignition or starter.</p><p></p><p>In the event of accident, you just turn the key, and it cuts battery power, fuel-pump, and ignition. If you have the regular "I wanna be racer look", even if you cut the switch, the car will continue to run as it draws power from the alternator when it is started.</p><p></p><p>As for clock, radio, alarm etc ... you can wire it to the life-side of the terminal, but make sure you fuse the components <img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/idea.gif" class="smilie" loading="lazy" alt=":idea:" title="Idea :idea:" data-shortname=":idea:" /></p></blockquote><p></p>
[QUOTE="eyong, post: 3626388, member: 23540"] I have used one of them before ... The FIA type (they are 300-500 ringgit) not your regular from Brothers or something. Basically it has two main poles, one on each sides for your battery cable. Then in-between the two main poles, are four slot-pins; a pair for fuel-pump; and another pair for ignition or starter. In the event of accident, you just turn the key, and it cuts battery power, fuel-pump, and ignition. If you have the regular "I wanna be racer look", even if you cut the switch, the car will continue to run as it draws power from the alternator when it is started. As for clock, radio, alarm etc ... you can wire it to the life-side of the terminal, but make sure you fuse the components :idea: [/QUOTE]
R35 Used Titanium Exhaust
New Toyota Sienta launched! Two variants, priced from RM93k
What's the deal?
UMW Toyota Motor Sdn Bhd today unveiled Toyota's latest Sienta for the...
looking for toyota mr-s body parts
i'm looking for toyota mr-s body parts,
during my car accident,
i'm already try my best to look for it
at some half cut shop d,
but im still need 1 more parts,
it's at right hand side window rubber
near the...
Selling Original S15 Steering Wheel with Airbag
Like the title says,i got an Original S15 Steering wheel with air bag for sale.Condition is good...only used for a few days.
Price : RM500
Call me at 012-2357991
Thanks!
sn964444
Main Forums
Interests
