Car Brands
Car Manufacturers
Mazda/Ford
B6 NA Overhaul issue
<blockquote data-quote="levin_boy" data-source="post: 3331561" data-attributes="member: 11965"><p>hey guys...</p><p></p><p>i'm driving a 1995 ford lynx with standard 1.6 NA manual.</p><p></p><p>Just wondering, i'm going to overhaul my engine soon, can i actually use a b8T crankshaft with my b6 block? what about the conrod and pistons? do i need to worry about piston rings? </p><p></p><p>another question is what is the biggest piston size that you guys think could be fitted into my current block</p><p></p><p>keep in mind that my next plan is to use a TD05.</p><p></p><p>Thank you guys for all your info.</p></blockquote><p></p>
[QUOTE="levin_boy, post: 3331561, member: 11965"] hey guys... i'm driving a 1995 ford lynx with standard 1.6 NA manual. Just wondering, i'm going to overhaul my engine soon, can i actually use a b8T crankshaft with my b6 block? what about the conrod and pistons? do i need to worry about piston rings? another question is what is the biggest piston size that you guys think could be fitted into my current block keep in mind that my next plan is to use a TD05. Thank you guys for all your info. [/QUOTE]
david tao
Nissan Teana is the Best Local Assembly Exec Sedan at Asian Auto Industry Awards
https://www.zerotohundred.com/wp-content/uploads/2011/07/nis12-600x399.jpg
The recently concluded Asian Auto-Auto Industry Awards 2011 has seen the Nissan Teana 2.5 V6 drive home with the ‘Best Local Assembly...
guys i really need help
i cant find any skyline shops around, i went round sunway but none were ther, if u guys can guide me to some that will be great
Eclipse Turbine
guys currently my turbine is TD05H , dats wht i can see from outside..
isit possible its from eclipse turbine and mod into my engine..im driving 1.8GSR..
as i know its a rojak turbine from fins to housing..and wen i...
Car Brands
Car Manufacturers
Mazda/Ford
