Main Forums
Car Talk
Car Modification
B20 VTEC Piston
<blockquote data-quote="satria_neo" data-source="post: 1063720431" data-attributes="member: 119965"><p>Yes, just tell them the compression you require (the bore as well) and desired valve lift so they could cut the valve relief for you.</p><p></p><p>As for pistons, I have not heard of cast iron ones, only aluminum ones. Even if there is you would not want it. Weight reduction is critical for NA engine.</p><p></p><p>For piston slap, its mostly on turbo engines only due to excessive clearance needed for expansion. Its not that critical for NA.</p><p></p><p>Btw, this assumes you are getting custom pistons. I bought custom Wiseco ones before. Cost around Euro 150 each before shipping. Pretty ok price.</p><p></p><p>Just check out the net about the various properties of pistons eg. materials used etc. Also things like oil spray holes, so-called anti-detonation groves (don't know if it really works) etc....</p></blockquote><p></p>
[QUOTE="satria_neo, post: 1063720431, member: 119965"] Yes, just tell them the compression you require (the bore as well) and desired valve lift so they could cut the valve relief for you. As for pistons, I have not heard of cast iron ones, only aluminum ones. Even if there is you would not want it. Weight reduction is critical for NA engine. For piston slap, its mostly on turbo engines only due to excessive clearance needed for expansion. Its not that critical for NA. Btw, this assumes you are getting custom pistons. I bought custom Wiseco ones before. Cost around Euro 150 each before shipping. Pretty ok price. Just check out the net about the various properties of pistons eg. materials used etc. Also things like oil spray holes, so-called anti-detonation groves (don't know if it really works) etc.... [/QUOTE]
Rotating Turbo Compressor Housing ...
Installing the new turbo and Intercooler piping but need to rotate the compressor housing prior to clearance issue,is it easy?
How to do it ?
FYI,the turbo have Internal Wastegate so the actuator still attached to...
Looking for RE Amemiya ADGT 11 bodykit
Hi ,
Im looking for a set of a RE Amemiya Bodykit, and of course not ori...hehe Fiber will do..
any sifus here got any contacts..??
thanks in advance...
Best Regards,
Akina Teo
fs: varis rear boot
rm 2900 new
e789
call 012 2083222
Main Forums
Car Talk
Car Modification
B20 VTEC Piston
