Main Forums
Car Talk
Car Modification
B20 modification
<blockquote data-quote="crxdelsol" data-source="post: 4379735" data-attributes="member: 80599"><p>Guys, I have a real headache issue. Since dropping my ride with B20, I've been having so much problem that my ride went back to the garage 4 times to have it refix. This time, the chief mechanic told me a shocking way to solve the problem. Maybe I shall tell you guys my problem and you can post your advise.</p><p></p><p>After I've gotten my ride, the temperature very unstable. And I have to top up the coolant/ water in the radiator or reservoir tank every 2 days. So I brought back to them for the 1st time, they checked and say water went into the header. So gasket change. Then took the car back. Same thing after 3 weeks. Again brought back to them, again water inside the head. Yesterday brought the car back to them because Im so sick of it having drop to B20 1 1/2 months back, and the problem not solved. I haven't even tune my ride because no tuner wanna tune it. So the chief mechanic call me and found out the real cause of problem. The metal pipe that channel water from the radiator to the engine corrode and therefore causing a leak, thats why water went into the head. So he say he will change the pipe. What cause me to alarm was, he say need to put double gasket because he cannot skim the head again cause already skimmed before. WTF! How can put 2 gasket. Can I ask him to get me another head? Any guys can share your opinion? Thanks</p></blockquote><p></p>
[QUOTE="crxdelsol, post: 4379735, member: 80599"] Guys, I have a real headache issue. Since dropping my ride with B20, I've been having so much problem that my ride went back to the garage 4 times to have it refix. This time, the chief mechanic told me a shocking way to solve the problem. Maybe I shall tell you guys my problem and you can post your advise. After I've gotten my ride, the temperature very unstable. And I have to top up the coolant/ water in the radiator or reservoir tank every 2 days. So I brought back to them for the 1st time, they checked and say water went into the header. So gasket change. Then took the car back. Same thing after 3 weeks. Again brought back to them, again water inside the head. Yesterday brought the car back to them because Im so sick of it having drop to B20 1 1/2 months back, and the problem not solved. I haven't even tune my ride because no tuner wanna tune it. So the chief mechanic call me and found out the real cause of problem. The metal pipe that channel water from the radiator to the engine corrode and therefore causing a leak, thats why water went into the head. So he say he will change the pipe. What cause me to alarm was, he say need to put double gasket because he cannot skim the head again cause already skimmed before. WTF! How can put 2 gasket. Can I ask him to get me another head? Any guys can share your opinion? Thanks [/QUOTE]
Subaru Impreza GC8
R35 Used Titanium Exhaust
battery kill switch ?
i read some articles bout someone having it in the car
can I ask what does it actually mean ?
it will switch off the battery so that the car won't turn on if not on ?
if so , i think it is quite useful for...
TRD Full scale Meter for 5AT
It seems that quite a number of members here are looking for the elusive full scale meter (240km/h) for our 5AT Altezza. I have searching around the web for new or used units but it to no avail.
Recently I have post...
RB26DETT - HKS Cams & APEXi Cams - For Sale
A few RB26DETT Hi-Lift Cams for Sale:
Apexi - V-MAX RB26DETT Camshaft IN 280- lift 11.5
V-MAX RB26DETT Camshaft EX 280- lift 11.5
Part number: 821-N010 / 821-N011
RM2500 nego...
jeff6126
Main Forums
Car Talk
Car Modification
B20 modification
