Audiosystem F4-600
ICE -In Car Entertainment
Audiosystem F4-600
tt_studio
Audiosystem F4-600!
Big and powerful amp,made in Italy.
Used, superb and pretty condition!
Price -SOLD-. COD KL area or courier.
Interested pls PM.
Thanks.
Stereo Power RMS @ 4ohm Watt 145 x4
Stereo Power RMS @ 2ohm Watt 230 x4
Dynamic Stereo power @ 2ohm Watt 320 x4
Bridged Mono Power RMS @ 4 ohms 460 watts x2
Load impedance min. 2 Ohm Stereo
Load impedance min. 4 ohms bridged mono
Damping Factor @ 4 Ohm -> 300
Range from 0.17 to 4.3 mV input sensitivity
Kohm input impedance> 11
Filter [amount] Type - [2] HP or LP
Operating band of 45-300 Hz filter
Slope of the filter dB / oct. 12
Frequency Response-3dB Hz 10-165000
THD @ 1 KHz - 90% rated power. 4ohm% DIM distortion - 90% rated power. 4ohm% S / N Ratio - 10Hz-22KHz - 90% rated power. 104 dB
Signal / noise ratio "A" weighted - 10Hz-22KHz - 90% rated power. 106 dB
Voltage range of 10.5 to 16 Volt
Section min. power cable for 5 mt. in length - Metric 35 mm2
Section min. power cable for 5 mt. in length - U.S. AWG 2
Maximum absorbed current A 63 Stereo @ 4ohm
Maximum input current Mono bridged @ 4ohm A 110
Quiescent current - no input signal A 1.32
Minimum current consumption - amplifier off 2 mA
Fuses 3x 40 °
Weight 4.6 Kg
Dimensions W x D x H mm 220x550x50
