Main Forums
General Talk
Atf or Fuel Hose
<blockquote data-quote="Rex551" data-source="post: 4146330" data-attributes="member: 80639"><p>leynye,</p><p>Since you've got an atf cooler installed it should definitely help bring down the operating temperature of your Transmission fluid. </p><p></p><p>The best thing to do right now is, monitor the hose from time to time while gathering information on it's maximum operating temperature which I also don't know.</p><p></p><p>Dah install, tak kan nak buka balik pulak...</p><p></p><p>I think it should be fine. I'm using the Red Goodyear hose for my V6 ATF cooler.</p></blockquote><p></p>
[QUOTE="Rex551, post: 4146330, member: 80639"] leynye, Since you've got an atf cooler installed it should definitely help bring down the operating temperature of your Transmission fluid. The best thing to do right now is, monitor the hose from time to time while gathering information on it's maximum operating temperature which I also don't know. Dah install, tak kan nak buka balik pulak... I think it should be fine. I'm using the Red Goodyear hose for my V6 ATF cooler. [/QUOTE]
david tao
What mods to do on a rb25det for around 400hp?
As the topic implies, can i get some rough idea what to completely modify for a stock rb25det in order to get around 400hp?
i currently only have 3inch piping, afm upgrade,intercooler, fuel pump and exedy single...
Rx8..!! advice needed..!!
bro...i`m planning to buy an rx8 but i had a lot of rumor that rx8 consume high petrol just like GTR but not as powerful..!! that make me so sad...so can all bro who using rx8 here can tell me how much is the full...
Find RX7 FD3S
Main Forums
General Talk
Atf or Fuel Hose
