Main Forums
Car Talk
Car Modification
Atf Cooler
<blockquote data-quote="Jack_Hon" data-source="post: 2533152" data-attributes="member: 53378"><p>For normal car, no need to added external ATF cooler, intergrad ATF cooler bottom of the radiator........</p><p></p><p>For modified car, sure definetly need external ATF cooler in order to reduce ATF temp.............</p><p></p><p>if modified car.........no extrenal ATF cooler, friction clutch disc so easily worn out.........</p><p></p><p>It's just depend u want install external oil cooler or not only.......if added definetly AT life span more longer.....</p><p></p><p>the same thing with human...</p></blockquote><p></p>
[QUOTE="Jack_Hon, post: 2533152, member: 53378"] For normal car, no need to added external ATF cooler, intergrad ATF cooler bottom of the radiator........ For modified car, sure definetly need external ATF cooler in order to reduce ATF temp............. if modified car.........no extrenal ATF cooler, friction clutch disc so easily worn out......... It's just depend u want install external oil cooler or not only.......if added definetly AT life span more longer..... the same thing with human... [/QUOTE]
R35 Used Titanium Exhaust
Hankook V12 Evo2 finally here
My friend saw these in tyre shop (Acanta), finally here, really long wait.....:driver...
Mugen CR-Z in the flesh
https://www.zerotohundred.com/wp-content/uploads/2011/05/crz1-600x399.jpg
Up to this point, all we’ve had to go on are renderings and speculated details regarding the spiced up version of Honda’s CR-Z, the Mugen...
Xtreme Evo engine Build 1000hp
Last a week meeting with profesional engine build and Engineering Factory from Australia agree to SPONSOR set of Dog Gear for Anybody build the Evo engine under 3rd GearPerformance Racing with 1000whp for Xtreme Drag...
sn964444
Main Forums
Car Talk
Car Modification
Atf Cooler
