Main Forums
Car Talk
ARB Bushings
<blockquote data-quote="tajulsans" data-source="post: 808609" data-attributes="member: 4192"><p>Its quite hard to reach, i'm not sure can change without removing the cross member.. If can also mechanic sure wont do as its too hassle, jack up, remove some screw and the cross member is lowered down oledi..</p><p></p><p><span style="font-size: 10px">depending on your engine but if wira 4g9x, have to remove power steering pump first because the the pump bracket will interfere one of the mounting nuts, however some exhaust shop will just cut some portion of the bracket to reduce the hassle.</span></p></blockquote><p></p>
[QUOTE="tajulsans, post: 808609, member: 4192"] Its quite hard to reach, i'm not sure can change without removing the cross member.. If can also mechanic sure wont do as its too hassle, jack up, remove some screw and the cross member is lowered down oledi.. [size=2]depending on your engine but if wira 4g9x, have to remove power steering pump first because the the pump bracket will interfere one of the mounting nuts, however some exhaust shop will just cut some portion of the bracket to reduce the hassle.[/size] [/QUOTE]
gear box problem?help
just got my car for few weeks, and i notice that the car's temperature is real high, it's hot on its surrounding outside the car, and i understood that a turbo car is used to like that. the only thing is even inside...
Patrs from Japan
Looking for rare parts for Lancer, try Yahoo Japan links
http://www.bidtrade.com.my/cacp.html#mitsu_parts
Translate language,
http://www.google.com/translate_t
Regards,
Paulson
RX8 or RX7??
Can anyone tell me which car is better??
Noticed that a lot of discussions on RX7, what about rx8??
Main Forums
Car Talk
ARB Bushings
