Main Forums
Car Talk
Car Modification
Apexi Open Pod problem
<blockquote data-quote="ekinomae" data-source="post: 914367" data-attributes="member: 18914"><p>Maybe should use heat shield with open pod?? So that no hot air is being sucked into the intake...</p></blockquote><p></p>
[QUOTE="ekinomae, post: 914367, member: 18914"] Maybe should use heat shield with open pod?? So that no hot air is being sucked into the intake... [/QUOTE]
R35 Used Titanium Exhaust
Ferrari 599 SA Aperta puts the ‘X’ in exclusive
http://www.zerotohundred.com/?attachment_id=14958
Ferrari has finally unveiled the drop-top roadster version of their 599 that will make its public debut at Paris in a weeks time and is limited to only 80 units...
Ek4 b16a a/t jerking
helo gang/sifu...
what the simpton...if
my car can't reverse when engin fast start?wait until engine running 10 min..and can reverse.
2} sometimes jerking if drive car ,,temperature sensor below setengah atau...
skyline stuff to let go cheap!
letting go of some stuff, previously in my skyline ER34
1. air flow sensor (not sure is this the correct term :) ) asking rm200
2. OEM coil packs ( 1 or 2 might be defective hence the...
sn964444
Main Forums
Car Talk
Car Modification
