Car Brands
Car Manufacturers
Honda
anybody pl help....
<blockquote data-quote="Riezal-R" data-source="post: 477910" data-attributes="member: 5811"><p>Just had this sort of problem recently. It was a faulty oil switch on my distributor for my case. But yours might not be the same. My sypmtoms were same, check light comes on while engaging VTEC in 3rd gear (only during pick-up). Check light won't go off and my VTEC wont engage until i restart the car. </p><p></p><p>It has also happen when the exhaust sensor is dirty/loose. VTEC can still engage but check light stays on.</p><p></p><p>Thing is, even if the check light isn't flashing, doesnt mean you cant get the error code. When the check light comes on, you can actually 'tap' the ECU wiring and the check light will flash. You can then see the error code and start tracing the fault. This was how I solved my problem. A Honda mech should be able to do this. </p><p></p><p>Good luck.</p></blockquote><p></p>
[QUOTE="Riezal-R, post: 477910, member: 5811"] Just had this sort of problem recently. It was a faulty oil switch on my distributor for my case. But yours might not be the same. My sypmtoms were same, check light comes on while engaging VTEC in 3rd gear (only during pick-up). Check light won't go off and my VTEC wont engage until i restart the car. It has also happen when the exhaust sensor is dirty/loose. VTEC can still engage but check light stays on. Thing is, even if the check light isn't flashing, doesnt mean you cant get the error code. When the check light comes on, you can actually 'tap' the ECU wiring and the check light will flash. You can then see the error code and start tracing the fault. This was how I solved my problem. A Honda mech should be able to do this. Good luck. [/QUOTE]
Advan GT Beyond 19 Civic Type R FK8 FL5 Rim Wheel
TE37 Saga S Plus 18 Civic Type R FL5 FK8
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Anybody successfully convert Lancer GT CVT to manual gb?
Just wanna ask anybody done it? Buy a 2nd hand MT from online
2008...
Trophy Teaser: (Racequeen Figurine not included) Time To Attack Finals next Sunday!
Take a look at the bespoke customized TTA Finals Trophy teaser for Dec 12! What you're looking at is the 3rd Place winner...
Unichip tuner
may like to install unichip to my car , i think the only 1 can perform dyno tuning around KL area is the RS IMPRESSIVE at Puchong , anybody try dyno there b4 ? good tuner ?:hmmmm:
Car Brands
Car Manufacturers
Honda
anybody pl help....
