Car Brands
Car Manufacturers
Nissan
ALTIMA: Cold start problem
<blockquote data-quote="jgsh" data-source="post: 2002085" data-attributes="member: 11235"><p>Hi there,</p><p></p><p>I am having this cold start problem. When my car is left "parked" for > 5hrs (approx.), I find it rather difficult to start. I can crank and crank and it just won't start. I can tell the starter's working though. If I leave the key position to the "start" long enough, it'll kick in, CHOKINGLY! I can feel the whole engine vibrating as if it's gasping for air/fuel.</p><p></p><p>On a different startup attempt, the moment I depressed the accelerator a little (during cold start), the car cranks smoothly, no choking whatsoever.</p><p></p><p>Also, once the "first" cold start is successful, all subsequent start is a breeze!</p><p></p><p>These had been looked at:</p><p>a. Battery replaced</p><p>b. Starter replaced</p><p>c. Spark plugs replaced</p><p>d. Engine oil level ok</p><p>e. Air filter replaced</p><p></p><p></p><p>After enquiring around, here are the summary of the "usual" suspects:</p><p>a. Failing alternator - if so, wouldn't I have this problem on every start? (I only have this problem when car left "parked" for a long time)</p><p>b. Fuel pump</p><p>c. Distributor - same as "a"?</p><p>d. Cold start valve - Been searching through the FSM, can't seem to identify the location of it.</p><p></p><p>Any thoughts?</p></blockquote><p></p>
[QUOTE="jgsh, post: 2002085, member: 11235"] Hi there, I am having this cold start problem. When my car is left "parked" for > 5hrs (approx.), I find it rather difficult to start. I can crank and crank and it just won't start. I can tell the starter's working though. If I leave the key position to the "start" long enough, it'll kick in, CHOKINGLY! I can feel the whole engine vibrating as if it's gasping for air/fuel. On a different startup attempt, the moment I depressed the accelerator a little (during cold start), the car cranks smoothly, no choking whatsoever. Also, once the "first" cold start is successful, all subsequent start is a breeze! These had been looked at: a. Battery replaced b. Starter replaced c. Spark plugs replaced d. Engine oil level ok e. Air filter replaced After enquiring around, here are the summary of the "usual" suspects: a. Failing alternator - if so, wouldn't I have this problem on every start? (I only have this problem when car left "parked" for a long time) b. Fuel pump c. Distributor - same as "a"? d. Cold start valve - Been searching through the FSM, can't seem to identify the location of it. Any thoughts? [/QUOTE]
original rare Yokohama ADVAN Racing RG3 18x8.5jj...
david tao
~accident repair ~touch up paint
jeff6126
Universal front bonnet scoop
jeff6126
Mitsubishi Lancer/inspira Evo front bonnet hood
jeff6126
Honda civic fc gtwing spoiler
jeff6126
Mitsubishi Lancer ~Evo front bumper
jeff6126
accident repair spray painting color
jeff6126
Subaru Impreza GC8
Team Malaysia drives home third at Shell FuelSave Challenge
https://www.zerotohundred.com/wp-content/uploads/2011/07/shell-600x450.jpg
The battle to be the region’s top Shell FuelSave Team came to a conclusion recently with Team Malaysia coming home third against drivers...
Anybody interested in DIY change meter face?
Anybody want to know how to DIY the changing of meter face to custom one?
Im in the process of doing it.. so if anybody interested can reply here.. if not
i just keep to myself.
Power FC + Commander for Altezza
Guys,
Anyone of you have this things on your ride?
How the performance?
http://img99.imageshack.us/img99/6421/pfcdo8.th.jpg
rem
david tao
Car Brands
Car Manufacturers
Nissan
