Car Clubs
Car Club Categories
Mitsubishi Lancer Owners Club
Air Flow Sensor Problem
<blockquote data-quote="jameswwt" data-source="post: 3969103" data-attributes="member: 61059"><p>AGREED...Can check the throttle body as well especially the small screw where we tune for the up & down rpm...Last time i face the same problem and need to crank at least 5 to 6 times for the engine to start every morning...Finally,found out is the small screw were to loose (hope i describe it right) and when tighten it a bit everything goes well til now...</p></blockquote><p></p>
[QUOTE="jameswwt, post: 3969103, member: 61059"] AGREED...Can check the throttle body as well especially the small screw where we tune for the up & down rpm...Last time i face the same problem and need to crank at least 5 to 6 times for the engine to start every morning...Finally,found out is the small screw were to loose (hope i describe it right) and when tighten it a bit everything goes well til now... [/QUOTE]
R35 Used Titanium Exhaust
87mm vg30 piston + 4D68 94mm crank + stock evo conrod, bolehkah?
Hi all,
Anyone tested the above setup?
Is this the way for makin 2.2L?
What about 4D68 crank with stock evo piston n rod?
Please help.
Silvia S15 2JZ
does silvia s15 can take the power of 2JZ under the engine bay !!! does any spot welding needed !!!!
central locking not working properly
My central locking just went kookoo already.... everything is still working fine, the anti-hijack, impact sensors, alarm.. foot brake lock, etc...
but the central locking just can't work if i manually unlock fr the...
Car Clubs
Car Club Categories
