Main Forums
Car Talk
Car Modification
After conversion
<blockquote data-quote="weslee" data-source="post: 3017491" data-attributes="member: 37765"><p>guys, needs some help here. after conversion of my waja 4G18 to 4G92 i tempted to use back my ori alarm which the key+remote is attached in 1 piece. </p><p></p><p>The problem is, i need wiring diagram for those ori alarm so that i can fix it back. Appreciate if anyone could furnish me the diagram or way to test the wiring. Thanks.</p></blockquote><p></p>
[QUOTE="weslee, post: 3017491, member: 37765"] guys, needs some help here. after conversion of my waja 4G18 to 4G92 i tempted to use back my ori alarm which the key+remote is attached in 1 piece. The problem is, i need wiring diagram for those ori alarm so that i can fix it back. Appreciate if anyone could furnish me the diagram or way to test the wiring. Thanks. [/QUOTE]
R35 Used Titanium Exhaust
Formula One numbers crunched in your favourite form
You probably already know that a modern steering wheel for a Formula One car costs as much as your average mid-sized sedan but...
WTA: Fully Adjustable Suspension
Hi all,
Just wondering where can i get item as mentioned for Hyundai i30 in Malaysia?Being searching and asking around,but it seems quite hard to get it. Home to get some advice at here.
Thanks.
Oil Filter Relocation ....
Hi pals, I just read an articles on net. It said that is a kits called Oil filter relocation kits. Did any of you all try it before ?
If yes please comment, or where can I get this kits from..
Thank you... guys
ponen
Main Forums
Car Talk
Car Modification
After conversion
