Car Clubs
Car Club Categories
Mitsubishi Lancer Owners Club
After changing timing belt
<blockquote data-quote="pangyau" data-source="post: 4097219" data-attributes="member: 82450"><p>For 1st week having the "noise" problem. They do adjust the tensioner.</p><p>the head mechanic claim might be his worker tight to hard then he re-adjust.</p><p>Next day ok... But after 2nd day the "nosie" problem re-occur.</p><p>I already tired due to spent more time in the workshop rather then drive the car.</p><p></p><p>Then I request them to change the whole set to OEM parts.</p><p>Seems all fine after that... I feel relief... Even tried my speed cut limitation.</p><p></p><p>Power Enterprise is a good brand but sometimes had bad luck getting faulty parts.</p><p>But on TODA... Kinda good also....</p></blockquote><p></p>
[QUOTE="pangyau, post: 4097219, member: 82450"] For 1st week having the "noise" problem. They do adjust the tensioner. the head mechanic claim might be his worker tight to hard then he re-adjust. Next day ok... But after 2nd day the "nosie" problem re-occur. I already tired due to spent more time in the workshop rather then drive the car. Then I request them to change the whole set to OEM parts. Seems all fine after that... I feel relief... Even tried my speed cut limitation. Power Enterprise is a good brand but sometimes had bad luck getting faulty parts. But on TODA... Kinda good also.... [/QUOTE]
Kumakubo's new D1 Laurel gets the shakedown
http://www.zerotohundred.com/?attachment_id=19826
Before you get disappointed watching the full video, let me be the first to tell you that there isn't any drifting in this video, it only shows some track footage of...
FS: Evo Stock Cams, Injector, Turbo
Have the following e6 items for sale. Suitable for Evo 4 engines, Airtrek upgrades.
1. E6 Cams set (RM1000 NETT)
- Intake Cams 256 Duration Degree, Lift 10.0mm
- Exhaust Cams 260 Duration Degree, Lift 9.5mm
Note...
EVO air flow sensor
Hi all sifu,
Can we upgrade vr4 200 hp air flow sensor to EVO 609 MAF?
DO we need the EVO socket too? How to match the wiring???
Car Clubs
Car Club Categories
