Car Brands
Car Manufacturers
Toyota
ae92 Rear Disc Brek Not Function..Why??
<blockquote data-quote="TRDae92" data-source="post: 3244602" data-attributes="member: 10808"><p>What i know is when u driving using foot brake, is normal, bcos it use the brake fluid to pump the caliber piston pushing the brake pad to grab the disc, If u using handbrake, it only using the internal stainless steel line to pull the trigger gear at the back for the rear disc, cable housing is the one to hold and protect the internal line and also handbrake pulling level strength. </p><p></p><p>If the spring housing for the brake cable is bended and crack , the internal stainless steel line is doing jobless. I facing this before and then change it. Now good and brake as normal. Thumb up~~~</p></blockquote><p></p>
[QUOTE="TRDae92, post: 3244602, member: 10808"] What i know is when u driving using foot brake, is normal, bcos it use the brake fluid to pump the caliber piston pushing the brake pad to grab the disc, If u using handbrake, it only using the internal stainless steel line to pull the trigger gear at the back for the rear disc, cable housing is the one to hold and protect the internal line and also handbrake pulling level strength. If the spring housing for the brake cable is bended and crack , the internal stainless steel line is doing jobless. I facing this before and then change it. Now good and brake as normal. Thumb up~~~ [/QUOTE]
Gab Sport spring on standard absorber.
wrong section/mod please delete this thread
Mod please delete :)
Guess it ...
here's a link in mudah 180 sx for sale...for real?? http://www.mudah.my/Nissan+Silvia+M+-16323241.htm the pic is flawless
Home grown talent to join test ranks at Ferrari
http://www.zerotohundred.com/?attachment_id=16662
There seems to be two main approaches to acquiring a new driver in the Formula One ranks. Team principles either seem to go with a seasoned veteran that has dealt...
Car Brands
Car Manufacturers
Toyota
