good news!!.... I check with my formen already... and confirm these headlight and body kit are perfectly fit to SE hatchback and no modify are need to do at all.. Just plug and play
So for those who using the Toyota SE hatchback, are able to upgrade to Levin Sprinter with no mod at all...:shades_smile:
Errmm.... EE90? u mean Malaysia Toyota SE (Sedan)?
If yes... you need to buy completely... but the bonet, i not sure.
If you are Toyota SE (Hatchback)... You just need the fender and grill only. the other thing are same as the OEM 1....
Just wanted to know why my car engine turn off (stall) by itself when cruising at the normal speed (mostly second gear...). It happens once in a while. I'm using a 4G63T (EII) with a stock bypass valve. No...
