Car Brands
Car Manufacturers
Toyota
AE111 can crank but engine start
<blockquote data-quote="Lawcc" data-source="post: 1064366013" data-attributes="member: 15652"><p>Starter can crank but engine won't start</p><p></p><p>My manual corolla seg stock engine keep giving me this problem. Today is the third time. I am really hopeless now.</p><p></p><p>First time (2 weeks ago) it happened, just call mechanic, he just open and close the fuel outlet near firewall, then it was ok.</p><p></p><p>I suspect it could be due to alarm issue, then go and install a new alarm. On that night, the same problem happened again. The installer just use additional wire to connect the fuel wire to a connector to bypass, then it was ok.</p><p></p><p>This morning, the same issue happens again. After dinner, come back try luck to start, it was ok.</p><p></p><p>Below is the history</p><p>1. the car overheated 1~2 years ago.</p><p>2. change radiator</p><p>3. earlier engine die off while driving on the road, change distributor, its wiring, spark plugs and plug cables.</p><p>4. fuel pump changed</p><p>5. recently change engine gasket, timing belt, water pump etc...</p><p></p><p>What could be the reason? Please help.</p><p></p><p>Thanks a lot.</p></blockquote><p></p>
[QUOTE="Lawcc, post: 1064366013, member: 15652"] Starter can crank but engine won't start My manual corolla seg stock engine keep giving me this problem. Today is the third time. I am really hopeless now. First time (2 weeks ago) it happened, just call mechanic, he just open and close the fuel outlet near firewall, then it was ok. I suspect it could be due to alarm issue, then go and install a new alarm. On that night, the same problem happened again. The installer just use additional wire to connect the fuel wire to a connector to bypass, then it was ok. This morning, the same issue happens again. After dinner, come back try luck to start, it was ok. Below is the history 1. the car overheated 1~2 years ago. 2. change radiator 3. earlier engine die off while driving on the road, change distributor, its wiring, spark plugs and plug cables. 4. fuel pump changed 5. recently change engine gasket, timing belt, water pump etc... What could be the reason? Please help. Thanks a lot. [/QUOTE]
R35 Used Titanium Exhaust
Longest-owning Proton owner wins a brand new Saga
Proton recently announced the winner of their Proton Search...
New tuning package by Underground Racing for Gallardo Superleggera does 403km/h
Video: New 1500whp tuning package by Underground Racing for Gallardo Superleggera
Please advice on this version of Defi VSD
Dear fellow members,
I'll be grateful if anyone can recognise this version of Defi VSD. I don't have a clearer pics of it for now and this is the best i can provide. I've come to realize that the shown Defi VSD...
Car Brands
Car Manufacturers
Toyota
