Main Forums
Car Talk
Car Modification
Adjust Ignition timing
<blockquote data-quote="Freedom_Blue" data-source="post: 910124" data-attributes="member: 14113"><p>About the belt normaly the thighter the better becoz it will lose the sound like kik.kik.kik.Maybe the belt needs to be change or might be some other foulty.Normaly is best to take to a mech that uses the tuning mechine.Take it to EON and explain what u want or facing.Normal charges are around RM25-RM28.</p></blockquote><p></p>
[QUOTE="Freedom_Blue, post: 910124, member: 14113"] About the belt normaly the thighter the better becoz it will lose the sound like kik.kik.kik.Maybe the belt needs to be change or might be some other foulty.Normaly is best to take to a mech that uses the tuning mechine.Take it to EON and explain what u want or facing.Normal charges are around RM25-RM28. [/QUOTE]
R35 Used Titanium Exhaust
NAP REVIEW 2012 - anyone following this?
Skyliners, anyone following this closely. NAP 2012 review will be announce soon. from what i have gathered probably in late Oct or Nov (or change due to political reason).
Anyway, the main points are:
1) Malaysia as...
used TE37 19inch
i guys i got a set of used TE37 GTr rim for sale.....
19" 9and half JJ offset 12
without tyres!!!!!
rm7200nego
012 669 0525
017 366...
can DIY repair rust?
hi all...
i got many spot got rust on the car body...
can DIY ?
i thinking...
1. use sand paper or machine sander/dremel with wire mesh bit to remove rust
2. take it to shop with welding machine ask them weld (...
vr2turbo
Main Forums
Car Talk
Car Modification
