Main Forums
Car Talk
Car Modification
Add turbo kit on 4g13p
<blockquote data-quote="Dino@Casper" data-source="post: 1255893" data-attributes="member: 13328"><p>skywalker u got it all wrong with the compression thing.. normally when we say high compression engine it doesn't actually mean high compression engine.. the Compression ratio we are talking about this actually the VOLUME at BDC (Bottom Dead Center) and TDC (Top Dead Center) do not be confuse with the meaning of compression... its actually a ratio of volume... Turbo car need lower compression ratio is because we need more volume TDC if not when the air n fuel mix together in a very small area the fuel reach its flash point faster and therefore result in the effect call pinging... which is bad for the engine n bad for hp gain..</p><p></p><p>So turbo engine actually has to be able to withstand high compression in other words high pressure.. as the air coming in are normally are two times higher in pressure than our atmosphere.. and actually botling a small turbo to a car like this is actually quite good in a way.. boosting maybe at a maximum of 0.5 its more than enough 2 put abit of fun factor and give you the power when u need it.. and there isn't much lag... nice mod u have there</p></blockquote><p></p>
[QUOTE="Dino@Casper, post: 1255893, member: 13328"] skywalker u got it all wrong with the compression thing.. normally when we say high compression engine it doesn't actually mean high compression engine.. the Compression ratio we are talking about this actually the VOLUME at BDC (Bottom Dead Center) and TDC (Top Dead Center) do not be confuse with the meaning of compression... its actually a ratio of volume... Turbo car need lower compression ratio is because we need more volume TDC if not when the air n fuel mix together in a very small area the fuel reach its flash point faster and therefore result in the effect call pinging... which is bad for the engine n bad for hp gain.. So turbo engine actually has to be able to withstand high compression in other words high pressure.. as the air coming in are normally are two times higher in pressure than our atmosphere.. and actually botling a small turbo to a car like this is actually quite good in a way.. boosting maybe at a maximum of 0.5 its more than enough 2 put abit of fun factor and give you the power when u need it.. and there isn't much lag... nice mod u have there [/QUOTE]
david tao
MY RIDE AUTOGROOMING @ Tmn/Wangsa Melawati WELCOMES RE Club Members!
Dear All
My Ride Autogrooming located at Taman Melawati and Wangsa Melawati welcomes you guys for any kind of services. Club Members can PM me for Special Car Wash & Detailing Services. Some of RE Club members are...
Z car gallery
Turbo Option
Hi all, have been quite some time since my last posting...
still enjoying my evo vii so far... did some upgrade and wear and tear replacement.
as of now, thinking of various options for the turbo:
(a) service the...
Main Forums
Car Talk
Car Modification
