Main Forums
Car Talk
Car Modification
accord sv4 H22A
<blockquote data-quote="rakyat" data-source="post: 4537844" data-attributes="member: 74468"><p>Ai-yo sweet already, unless u want to spend serious $$$ & crack open the engine. U can go for Port & polish, change hi-cams then install a engine mgmt (e-manage?) unit.</p><p></p><p>How much did Jaafar charge u for the full exhaust set-up? Wat diameter r your pipings?</p></blockquote><p></p>
[QUOTE="rakyat, post: 4537844, member: 74468"] Ai-yo sweet already, unless u want to spend serious $$$ & crack open the engine. U can go for Port & polish, change hi-cams then install a engine mgmt (e-manage?) unit. How much did Jaafar charge u for the full exhaust set-up? Wat diameter r your pipings? [/QUOTE]
david tao
Pic Lame 2004
Boring xtau nak wat per..so aku upload la pic lame nie..can't remember this function was before or after GT Japan 2004..enjoy!
I think most of us know this BNR32 owner..hehe...
Mitsubishi L200 Turbo
Thinking to add up some boost to my L200. Anyone know what is the max this engine can stand?? :_:
Anyway,its a diesel turbo:confused_smile:
How to install Monza Tachometer in Kelisa
I've been trying to install a monza tachometer in my kelisa but i just kept failing.
The manual says i should get the rpm reading from the ignition coil but kelisa is a bit more complicated than that.
I've tried...
Main Forums
Car Talk
Car Modification
accord sv4 H22A
