Main Forums
Car Talk
Car Modification
Absorber:Short stroke Vs Long Stroke
<blockquote data-quote="SkYwAlKeR" data-source="post: 1385575" data-attributes="member: 10341"><p>long stroke:</p><p>- usually an OEM replacement shocks</p><p>- mostly for comfort based</p><p>- maintain ur car height</p><p>- softer than short stroke shocks</p><p></p><p>short stroke:</p><p>- usually to match aftermarket lowered springs</p><p>- mostly for performance</p><p>- lower ur car a little (max 1finger only)</p><p>- stiffer than long stroke shocks</p><p></p><p></p><p>a car standard height depends on the manufacturer's spec... for example, wira SE are already lowered at factory standard (about 2 fingers).... while cars like iswara has 6 to 7 fingers gap....</p><p></p><p>what's the height of ur car now??... if u want optimum height, go for adjustable coilovers... solves ur headache or getting too low or not low enough...</p><p></p><p>*btw, if u want to lower ur car, look into changing lowered springs... shocks has jz 1 height and usually not adjustable (unless u buy those semi-adjustable)*</p></blockquote><p></p>
[QUOTE="SkYwAlKeR, post: 1385575, member: 10341"] long stroke: - usually an OEM replacement shocks - mostly for comfort based - maintain ur car height - softer than short stroke shocks short stroke: - usually to match aftermarket lowered springs - mostly for performance - lower ur car a little (max 1finger only) - stiffer than long stroke shocks a car standard height depends on the manufacturer's spec... for example, wira SE are already lowered at factory standard (about 2 fingers).... while cars like iswara has 6 to 7 fingers gap.... what's the height of ur car now??... if u want optimum height, go for adjustable coilovers... solves ur headache or getting too low or not low enough... *btw, if u want to lower ur car, look into changing lowered springs... shocks has jz 1 height and usually not adjustable (unless u buy those semi-adjustable)* [/QUOTE]
david tao
cross flow exhaust for turbo engines
Dear turbos lover & expert
what do u think about stock standard exhaust for turbo engines......
i was trying to convince my fellow turbo friend, thats not right
technically speaking for a 2.5 litre turbo...
Zerotohundred words & logo
any1 have zerotohundred words & logo can send to me??
the words like the header & the logo hope can get full 1(dun wan half)...
hope the pics can be bigger & clear...
cus i wan to DIY...
DIY- How to spray engine head cover?
can someone please teach me how to spray engine head cover.:retarded:
what type of cleaning products should i use for oil free surface?
what type of paint to use?
thanks a lot....:embaressed_smile:
Main Forums
Car Talk
Car Modification
