Car Clubs
Car Club Categories
The Cefiro Club Malaysia
A33 engine jerk problem
<blockquote data-quote="Nightstalker1993" data-source="post: 1064712125" data-attributes="member: 100539"><p>Intermittent could even be faulty wiring, barely touching etc. Crank sensor, cam sensor, coil trigger wire, even o2 sensor faulty also might cause jerky... I would suggest you change another mechanic, depending on your location maybe someone can recommend a reputable mechanic around your area</p></blockquote><p></p>
[QUOTE="Nightstalker1993, post: 1064712125, member: 100539"] Intermittent could even be faulty wiring, barely touching etc. Crank sensor, cam sensor, coil trigger wire, even o2 sensor faulty also might cause jerky... I would suggest you change another mechanic, depending on your location maybe someone can recommend a reputable mechanic around your area [/QUOTE]
R35 Used Titanium Exhaust
4G93T GSR Lancer advice
Hi guys!
Im from Australia, and I've got a GSR Lancer (4G93T). I'm currently installing an upgraded turbo that I refurbished (standard TD04 was blowing smoke on boost), wanted to see how much power you guys think it...
2012 Audi A4 now in Malaysia
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash3/s720x720/538961_587838437740_283900550_2316002_1844995110_n.jpg
Euromobil has recently announced the arrival of the 8th generation Audi A4. Some quick highlights...
Tips and Trick!! Lets Share
Considering we've gpt loads of DIY guys here like Alchemis, Joewe, Sidewaysgrey etc lets share tips and tricks we've learned so far.
i'll Start -
You can buy Ford Extreme Side clear indicators to replaced dull old...
Car Clubs
Car Club Categories
