Main Forums
Car Talk
Forced Induction & Engine Management
93t and 93p air flow sensor different?
<blockquote data-quote="AlucarD" data-source="post: 172309" data-attributes="member: 1703"><p>Hi, replacing the air flow sensor on your 4G93P to the 93T IMHO does not increase HP. It will however make your car run smoother.</p><p></p><p>4G93P = 499</p><p>4G93T = 449</p><p></p><p>The NA air flow is not meant for turbo aplications, however it'll still work but you'll notice that your AF will fluctuate more during cruising and on-boost whereas with the turbo AF sensor AF will remain quite constant... I've changed mine before and can say that its a good mod.</p><p></p><p>Let me know if you're lookig for one... I have one to let go and its still running in my car now :P</p></blockquote><p></p>
[QUOTE="AlucarD, post: 172309, member: 1703"] Hi, replacing the air flow sensor on your 4G93P to the 93T IMHO does not increase HP. It will however make your car run smoother. 4G93P = 499 4G93T = 449 The NA air flow is not meant for turbo aplications, however it'll still work but you'll notice that your AF will fluctuate more during cruising and on-boost whereas with the turbo AF sensor AF will remain quite constant... I've changed mine before and can say that its a good mod. Let me know if you're lookig for one... I have one to let go and its still running in my car now :P [/QUOTE]
david tao
1992 MR2 front tyre size ?
hi all, can 225/40/17 install at the front of MR2 year 1992 (car lowered) ? any rubbing issue ?
because using 4 pcs same size tyre is easier for rotating....
what is the max size for in front ?
thx.
looking for few evo items
hi guys, im looking for few item below:
1) evo 6.5 front bumper, either ori or replica also can. or pls offer others style that can P&P onto evo 5/6 body.
2) evo 4 front disc rotor only - 1 pair ( if evo 5/6 is...
Mitsubishi cX CUV Concept For Frankrut Show
Over the last month, a steady stream of information has been released regarding Mitsubishi’s planned cX CUV Concept. Finally the picture becomes...
Main Forums
Car Talk
