Car Brands
Car Manufacturers
Toyota
6 Speed Blacktop question...
<blockquote data-quote="km_chew" data-source="post: 3439658" data-attributes="member: 4354"><p>No need to change.. but dun forget the linkage.. the 6speed ECU has a slightly diff upon you change gear (rpm go up a little) .. </p><p></p><p>|1A660 is for the 6 speed equipped AE111 which are compatible with 5 speeds as well but mated with 6 Speed transmission outputs, it has premature rev cut points in 1 st and 6th gear and slightly changed timing curves for a split second after lift throttle and reapplication to ease and protect the 6 speed's synchro and reduce driveline lash.| </p><p></p><p>url] technical page</p><p></p><p>Using 5sp BT's ECU with a 6sp gbox and it works fine on my car.</p></blockquote><p></p>
[QUOTE="km_chew, post: 3439658, member: 4354"] No need to change.. but dun forget the linkage.. the 6speed ECU has a slightly diff upon you change gear (rpm go up a little) .. |1A660 is for the 6 speed equipped AE111 which are compatible with 5 speeds as well but mated with 6 Speed transmission outputs, it has premature rev cut points in 1 st and 6th gear and slightly changed timing curves for a split second after lift throttle and reapplication to ease and protect the 6 speed's synchro and reduce driveline lash.| url] technical page Using 5sp BT's ECU with a 6sp gbox and it works fine on my car. [/QUOTE]
New Nissan S15 silvia tail lamp EURO
http://www.zerotohundred.com/newfor...ew-silvia-s15-tail-lamp-euro.html#post4316113
plz refer to this thread as limited units only
maintaining & upgrading
hello boys,
i need a rough estimate on the jobs im going to do so i can prepare some cash when the time comes. i realise im not a fully paid up member of mloc so i'd like to apologise if me posting here offends some...
DIY anti-rust electronic thingy??
hi everyone
i receive an advertising mail, it saids
got things thing, u pasang to your car
it can stop rusting one... and 'electronically' stop the rusting
is there anyone out there got circuit diagram know how...
Car Brands
Car Manufacturers
Toyota
