Car Brands
Car Manufacturers
Proton
Proton Inspira Forums
4WD Inspira
<blockquote data-quote="lancer evo 10" data-source="post: 1064062566" data-attributes="member: 134053"><p>If u guy want to convert evo 10 4wd, u must change u front and rear fender, because evo 10 and lancer center wheel base is diffrent.the evo 10 is 2650mm and lancer is 2635mm. Or u just change the lancer ralliart cba-cy4a '08 front and rear axle, this one is no need modifie u fender because the wheel base distane is same 2635mm. But u will lose alot electric support, like no more ayc,s-awd,s-abs etc..... .U just use normal electric LSD, evo 9 awd and abs.<span style="color: Silver"></span></p><p><span style="color: Silver"></span></p><p><span style="color: Silver"><span style="font-size: 9px">---------- Post added at 11:14 PM ---------- 6 hour anti-bump limit - Previous post was at 11:13 PM ----------</span></span></p><p><span style="color: Silver"></span></p><p><span style="color: Silver"></span>and one more is if u change evo 10 fender and chassis , u must add the space or change the off set rim.</p></blockquote><p></p>
[QUOTE="lancer evo 10, post: 1064062566, member: 134053"] If u guy want to convert evo 10 4wd, u must change u front and rear fender, because evo 10 and lancer center wheel base is diffrent.the evo 10 is 2650mm and lancer is 2635mm. Or u just change the lancer ralliart cba-cy4a '08 front and rear axle, this one is no need modifie u fender because the wheel base distane is same 2635mm. But u will lose alot electric support, like no more ayc,s-awd,s-abs etc..... .U just use normal electric LSD, evo 9 awd and abs.[COLOR="Silver"] [SIZE=1]---------- Post added at 11:14 PM ---------- 6 hour anti-bump limit - Previous post was at 11:13 PM ----------[/SIZE] [/COLOR]and one more is if u change evo 10 fender and chassis , u must add the space or change the off set rim. [/QUOTE]
david tao
DIY-Flush Engine Oil With ATF
Good day to all,
I use ATF-Automatic Transmission Fluid to flush my engine oil.
Did this after read it in the net. Some flush with kerosene.
visit this website: http://www.dokaugot.fotopic.net
180sx with rb26
I remember last time akimoto selling 1 180sx with Tomei rb26 from Seremban.
I have some questions:
1. Anyone know about the car? Is it reliable to drive? Or must be owned by mechanic only?
2. Did the workshop in...
Coloured the head cover
as i gonna dohc-ing my head to 4g93.so i think of make it become red.1st of all,should i take the head to spray then only put on or i should wait after the mech modded it then only i spray?
and can i spray it on my...
Car Brands
Car Manufacturers
Proton
4WD Inspira
