Main Forums
Car Talk
Car Modification
4G9X ignition timing
<blockquote data-quote="mengz" data-source="post: 2375255" data-attributes="member: 8556"><p>hey peras...thnks for the ignition timing info...so its 5 degree's BTDC at 700 rpm. thanks.</p><p></p><p>that autodata...issit some software? issit ok to send it to me??</p><p></p><p>p/s: the info regarding the valves...which is the figure for valve diameter?</p></blockquote><p></p>
[QUOTE="mengz, post: 2375255, member: 8556"] hey peras...thnks for the ignition timing info...so its 5 degree's BTDC at 700 rpm. thanks. that autodata...issit some software? issit ok to send it to me?? p/s: the info regarding the valves...which is the figure for valve diameter? [/QUOTE]
Emanage Ultimate - Guidance
Hi bro's.
just need some advice or help using the emu.
1) The emu is already tuned by a tuner. i wanted to run a datalog, so I connected my laptop to my emu, and a popup came up "Import data from emanage" and i...
How to fix superlon
Problems fixing superlon
Got SA 6mm, got it to fix on wira door panels.
Superlon seems to thick for the car door panel, cant close properly.
Anyone can help?
duckbill mask home testing - video proof
http://209.126.225.174/images/44.gifwicked funny videos here:
http://www.duckbill.tv
Main Forums
Car Talk
Car Modification
