Main Forums
Car Talk
Forced Induction & Engine Management
4G93T Engine pinging/knocking
<blockquote data-quote="Harrytech" data-source="post: 1063956452" data-attributes="member: 133089"><p>Thank you xtremeleo for your reply,</p><p></p><p>A bit of work to get to the crank angle sensor but I will give it a try, which way do I turn the sensor, clock wise or anti clock wise to retard the timing.</p><p></p><p>Cheers Harry<img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/driver.gif" class="smilie" loading="lazy" alt=":driver:" title="Driver :driver:" data-shortname=":driver:" /></p></blockquote><p></p>
[QUOTE="Harrytech, post: 1063956452, member: 133089"] Thank you xtremeleo for your reply, A bit of work to get to the crank angle sensor but I will give it a try, which way do I turn the sensor, clock wise or anti clock wise to retard the timing. Cheers Harry:driver: [/QUOTE]
david tao
ECU flash/remap for Evo 6 stock ecu
Hi all,
Does anybody know where I can get this done? Seems like this is quite a popular method overseas of retuning your ecu to deal with supporting modifications instead of changing the ecu. Anybody know any good...
Need help.. looking for clutch master pump
Hi.. i'm looking for clutch master pump for bnr32.. anybody know where can i get it? thanks in advance
[wts]FC Japan Fiber Side Mirror
Japan made fiber for
FC3S
side mirror, maybe u can fit or modify for other car.
-black colour
-anolock/manual (no power)
*no dent, still in very good condition!!
RM350
pair...
Main Forums
Car Talk
