Main Forums
Car Talk
4G92P jerking
<blockquote data-quote="jebatdex" data-source="post: 1064645975" data-attributes="member: 117680"><p>So far, what I did:</p><p>- replace plug cable</p><p>- replace fuel filter</p><p>- clean MAF using CRC MAF Cleaner</p><p>- replace distributor with half cut one</p><p></p><p>Now, the problem is; when I press the acceleration pedal abruptly, is will be bad jerking. After a few moment, it will be normal again. For example, going into SmartTag lane with gear 2, after the toll, start to accelerate, then jerking happened and back to normal after some time. If I want to avoid the jerking, need to accelerate/pick up speed very slowly, cannot be abruptly. Anyone has experienced this kind of problem? Maybe the halfcut distributor gives problem, but when I first installed it, no problem happened... :hmmmm::hmmmm::hmmmm:</p></blockquote><p></p>
[QUOTE="jebatdex, post: 1064645975, member: 117680"] So far, what I did: - replace plug cable - replace fuel filter - clean MAF using CRC MAF Cleaner - replace distributor with half cut one Now, the problem is; when I press the acceleration pedal abruptly, is will be bad jerking. After a few moment, it will be normal again. For example, going into SmartTag lane with gear 2, after the toll, start to accelerate, then jerking happened and back to normal after some time. If I want to avoid the jerking, need to accelerate/pick up speed very slowly, cannot be abruptly. Anyone has experienced this kind of problem? Maybe the halfcut distributor gives problem, but when I first installed it, no problem happened... :hmmmm::hmmmm::hmmmm: [/QUOTE]
R35 Used Titanium Exhaust
Yoichiro Ueno, New MD and CEO of Honda Malaysia
Today, Honda Malaysia announced the appointment of Yoichiro Ueno as MD and CEO with immediate effect.
Yoichiro Ueno, 47, previously the Assistant VP of Automobile Sales of American Honda Motor Co. Inc., where he was...
[WTA] Strawberry faced 180SX
I've been wondering alot, do any of you guys who drives a S15 facelifted 180SX get stopped by the 'gentlemens' about your car?
Yeah, as far as I'm concern, Nissan did not manufactured Strawberry 180SX. But Nissan...
sard attack meter diaghram
bro,
did anybody out there have install this unit in your car,can
share the diaghram or instruction manual for install it?
Main Forums
Car Talk
4G92P jerking
