Car Brands
Car Manufacturers
Proton
4G92P check engine light and jerking when idle
<blockquote data-quote="nyantong" data-source="post: 1064216396" data-attributes="member: 64108"><p>sudden drop in rpm could indicate improper air fuel mixture, in this case most likely air leak somewhere between the air flow sensor and intake manifold. try to search for any other leak including vacuum hoses. also if possible try and retrieve the fault code in the obd</p></blockquote><p></p>
[QUOTE="nyantong, post: 1064216396, member: 64108"] sudden drop in rpm could indicate improper air fuel mixture, in this case most likely air leak somewhere between the air flow sensor and intake manifold. try to search for any other leak including vacuum hoses. also if possible try and retrieve the fault code in the obd [/QUOTE]
R35 Used Titanium Exhaust
Ogura Single Plate for RB25
Brand new in box.... pm me... price i sell at 2K rm aje!!! brand new!!
gtr wide bumper
where can i get the gtr bumper and wide fender in kl?
and the price
headlamp wiring (relay)
I just at sent my kancil for headlamp(square) wiring modd . Mod for putting bigger wattage white blue bulb, but i notice that after changging those big wattage bulb , my speedometer light is gonna dim a bit and my...
Car Brands
Car Manufacturers
Proton
