Main Forums
Car Talk
Car Modification
4g92 SOHC To Dohc
<blockquote data-quote="AD_EG" data-source="post: 3604924" data-attributes="member: 74396"><p>maybe you should also consider getting a piggyback and get your car tuned..</p><p></p><p>get a adjustable cam pulley and set your cams...if you set for more pickup you'll have to remember that you'll lose some top end too.</p><p></p><p>and why not also go for a lighten flywheel and get a lighten crank pulley? that will help you car in the accelaration department too.</p><p></p><p>And like the sifu's also mentioned, your gearbox could be the cause of your worries too.</p><p></p><p>Bump: maybe you should also consider getting a piggyback and get your car tuned..</p><p></p><p>get a adjustable cam pulley and set your cams...if you set for more pickup you'll have to remember that you'll lose some top end too.</p><p></p><p>and why not also go for a lighten flywheel and get a lighten crank pulley? that will help you car in the accelaration department too.</p><p></p><p>And like the sifu's also mentioned, your gearbox could be the cause of your worries too.</p></blockquote><p></p>
[QUOTE="AD_EG, post: 3604924, member: 74396"] maybe you should also consider getting a piggyback and get your car tuned.. get a adjustable cam pulley and set your cams...if you set for more pickup you'll have to remember that you'll lose some top end too. and why not also go for a lighten flywheel and get a lighten crank pulley? that will help you car in the accelaration department too. And like the sifu's also mentioned, your gearbox could be the cause of your worries too. Bump: maybe you should also consider getting a piggyback and get your car tuned.. get a adjustable cam pulley and set your cams...if you set for more pickup you'll have to remember that you'll lose some top end too. and why not also go for a lighten flywheel and get a lighten crank pulley? that will help you car in the accelaration department too. And like the sifu's also mentioned, your gearbox could be the cause of your worries too. [/QUOTE]
david tao
US GP penned in for June 17 2012, full 2012 calendar included
https://www.zerotohundred.com/wp-content/uploads/2011/06/f1-600x430.jpg
This year’s Formula One race schedule has garnered some criticism for being too packed with 20 races crammed in but for 2012, things are going...
mr2 sw20 workshops in pj
any trusted workshops in the pj area? hopefully reasonable prices too
when will be the next skyline gatherinG?
remus...so things going on??u told me planned to had a skyline gathering this friday night??
Main Forums
Car Talk
Car Modification
4g92 SOHC To Dohc
