Main Forums
Car Talk
Car Modification
4G92 SOHC distributor
<blockquote data-quote="vr2turbo" data-source="post: 1064631636" data-attributes="member: 92229"><p>My Hyundai is Mitsu base so using distributor some more same as Proton 8V ones with external coil, but coil is Hyundai design.</p></blockquote><p></p>
[QUOTE="vr2turbo, post: 1064631636, member: 92229"] My Hyundai is Mitsu base so using distributor some more same as Proton 8V ones with external coil, but coil is Hyundai design. [/QUOTE]
david tao
Simple changing driveshaft boot with a cone
Instead of the conventional way of changing the boot by removing the whole driveshaft, and then whacking out the CV joint, I used a simpler way to get the boot onto the cv joint. Note: This method should only be used...
Max limit for TD04L turbo
Closed
Hi, is anybody tried the max boost using TD04L on a 1834cc engine at 7.5k RPM? Is it possible to get 1.1bar at 7.5k RPM? Will it kill the turbo?
apexi exhaust system
i have a set R34 apexi hybrid.exhaust system for sell rm1000...like new ..
call me 0124893661 n r34 standard turbox2 rm1400
Main Forums
Car Talk
Car Modification
