Main Forums
Car Talk
Car Modification
4g91 engine
<blockquote data-quote="tajulsans" data-source="post: 459429" data-attributes="member: 4192"><p>if u r concern bout FC than go for the EFI one.. dont worry bout the rpm as u can remove the rpm cut off if u want to..</p></blockquote><p></p>
[QUOTE="tajulsans, post: 459429, member: 4192"] if u r concern bout FC than go for the EFI one.. dont worry bout the rpm as u can remove the rpm cut off if u want to.. [/QUOTE]
R35 Used Titanium Exhaust
Tyre Pressure for 195/45/R15
How much pressure should i pump into this tyre ?
AT the moment i pump like 35psi for the front and 34psi for the rear ....
I see on my Polo with 215/40/R17 recommended pressure is 40Psi ... is it normal to run such...
Hagwalah – Saudi’s Drifting Phenomenon
The roads are one of the places where we could encounter a huge variation of human behavior; from those that follow the law, to...
water temp issue on rb25det....help... thanks
i wish to find out, with our hot weather esp during afternoon, whats your ride water temp and oil temp? both water n oil, for mine, are da same reading, for eg, if my water temp is at 80c den my oil wil b around that...
ae92joon
xa[V]ier
Main Forums
Car Talk
Car Modification
4g91 engine
