Car Brands
Car Manufacturers
Mitsubishi
4g67 hi comp
<blockquote data-quote="dino1711" data-source="post: 1063904730" data-attributes="member: 27163"><p>hi all, even this thread is old, but i'm going to share abit. sorry if i'm wrong. for oversize, i think sr16ve which is 86mm high compression or sr20ve but less compression. i also heard 4g61 na using vtec 87mm(from h22a or f20b if not mistaken) piston where i think the height of the piston is same with 4g67, just the matter is piston pin.. thanks.</p></blockquote><p></p>
[QUOTE="dino1711, post: 1063904730, member: 27163"] hi all, even this thread is old, but i'm going to share abit. sorry if i'm wrong. for oversize, i think sr16ve which is 86mm high compression or sr20ve but less compression. i also heard 4g61 na using vtec 87mm(from h22a or f20b if not mistaken) piston where i think the height of the piston is same with 4g67, just the matter is piston pin.. thanks. [/QUOTE]
PETRONAS Syntium Team Celebrates First Mercedes SLS AMG GT3 Win in Japan!
The...
SMT 5 bugs n probs did anyone face?
is there a lot of bugs in SMT 5?
did anyone face sucha problems? as iheard, da settings will changed automatically by itself...so da values will run wild...!!! did dis realli happen?
anyone? wif previous experience?
Hybrid turbines
How easy or difficult is it to get a hybrid turbine (like T3/T3, or T25/T3) done? I mean, is it plug and play, or are drilling and machining of new screw holes or parts/housings needed?
Car Brands
Car Manufacturers
Mitsubishi
4g67 hi comp
