Main Forums
General Talk
4g13 upgrading
<blockquote data-quote="darrengoh89" data-source="post: 4548499" data-attributes="member: 79630"><p>4g13 and 4g15 head is the same! .... only different is the block ...to stroke a 4g13 block to 1.5 is not recommended ...coz you will be facing reliability issue ...the cylinder wall will be too thin ..the max bore size for a 4g13 block without facing reliability issue is 74mm low compression piston ...which it would be 1430cc...if you wanna plonk in a 4g15 block ...then go for it ...don't worry about the head muz skim or not to fit in...no suchthing ...4g13 is a high compression engine is due to the piston ...not the head ...if you want high compression after plonking a 4g15 block ...send your head for high compression skim ..thats it ...in my humble opinion ...do it 1 shot if budget allowed ...do not make it a 2 times job in the end ...do 1 shot as in 1.6 stroker kit and PnP headjob ...</p></blockquote><p></p>
[QUOTE="darrengoh89, post: 4548499, member: 79630"] 4g13 and 4g15 head is the same! .... only different is the block ...to stroke a 4g13 block to 1.5 is not recommended ...coz you will be facing reliability issue ...the cylinder wall will be too thin ..the max bore size for a 4g13 block without facing reliability issue is 74mm low compression piston ...which it would be 1430cc...if you wanna plonk in a 4g15 block ...then go for it ...don't worry about the head muz skim or not to fit in...no suchthing ...4g13 is a high compression engine is due to the piston ...not the head ...if you want high compression after plonking a 4g15 block ...send your head for high compression skim ..thats it ...in my humble opinion ...do it 1 shot if budget allowed ...do not make it a 2 times job in the end ...do 1 shot as in 1.6 stroker kit and PnP headjob ... [/QUOTE]
R35 Used Titanium Exhaust
Help on Evo 7 Problem
Hi all, anyone ever experience car running only 2 piston suddenly when cruising?when stopped the engine and start back, the engine went normal back. When this happened, i've check the fuel pressure on regulator is...
greetings from singapore!
hello all!
a few of us here in sg may plan on a drive up to malaysia in nov/dec, perhaps kl. will be great if we can meet up with some zed drivers from the area.
gd opportunity for us to check out your cars and...
Guys pls help me with this..........
Need help from u guys...
im abit confused bout this problem....
1- Gearbox oil?? can i use Redline oil GL-4 MTL and MT90(need to mix)???
2- Transfer case n Rear diffrential?? can i use GL-5 Redline 75w90?? or
can...
sn964444
Main Forums
General Talk
4g13 upgrading
