Car Brands
Car Manufacturers
Toyota
4e-fte convert supercharge
<blockquote data-quote="xtremeleo" data-source="post: 970019" data-attributes="member: 18941"><p>turbo is alwiz better, fuel consumption wise. because of the way it works, by using the unwanted exhaust kinetic energy to generate more power. sc will lose its efficiency in higher rpm.</p><p>std ct9 is capable of kicking in as early as 1800rpm, IF u know how to play the throttle rite:)</p></blockquote><p></p>
[QUOTE="xtremeleo, post: 970019, member: 18941"] turbo is alwiz better, fuel consumption wise. because of the way it works, by using the unwanted exhaust kinetic energy to generate more power. sc will lose its efficiency in higher rpm. std ct9 is capable of kicking in as early as 1800rpm, IF u know how to play the throttle rite:) [/QUOTE]
Team Goodyear Drifting into Action This Formula Drift 2012 - Malaysia!
Goodyear Malaysia has their eye set on this year’s Formula Drift 2012, which will be taking...
Coolant Mix and Overheating
Dear Frenz,
Why a rich mix gives less cooling:
Now if you've poured coolant into a radiator, you have no doubt that it is much thicker than water. That is, it has a much higher viscosity. This means that it...
2010 Sepang 1000km Race: Team Kegani Racing is back. Introducing pilots of car #37
https://www.zerotohundred.com/wp-content/uploads/2010/06/2010-Kegani-Racing-Team-5-600x398.jpg
When asked who he regarded to be the team's closest competitor, team boss Kenny Lee's immediate response was, "our very...
Car Brands
Car Manufacturers
Toyota
