Car Brands
Car Manufacturers
Toyota
4AGE 20V Top Overhaul / Full Overhaul
<blockquote data-quote="pcmoddingmy" data-source="post: 3846407" data-attributes="member: 25616"><p>Wow... that's bad bro. How did it happen? The engine was fully rebuilt early this year right? I thought you were running toda pistons?</p><p>If no compression, the engine will sound like running on 3 pistons, maybe no smoke also because no combustion on the affected cylinder. Either piston damaged or block warped. I've seen a BT block warped out of shape, leaving empty spaces between the piston and cylinder which causes the compression loss.</p></blockquote><p></p>
[QUOTE="pcmoddingmy, post: 3846407, member: 25616"] Wow... that's bad bro. How did it happen? The engine was fully rebuilt early this year right? I thought you were running toda pistons? If no compression, the engine will sound like running on 3 pistons, maybe no smoke also because no combustion on the affected cylinder. Either piston damaged or block warped. I've seen a BT block warped out of shape, leaving empty spaces between the piston and cylinder which causes the compression loss. [/QUOTE]
R35 Used Titanium Exhaust
ER34 GTT oem front suspension
Hi all,
Anyone here where can i get GTT oem parts from?
I am looking for 1pc ER34 GTT OEM front suspension.
Thanks all.
wta: brake rotor...
hi all, any recommended good brake rotor ? how much it cost usually ?
need to change together both front and rear ?
if change front only... boleh jadi tak balance arh ?
Original Evo4 suspension for sale
Evo 4. Condition : Excellent..Price : RM500. PM please
:sleep:
https://www.zerotohundred.com/forums/attachments/117162.vB
Car Brands
Car Manufacturers
Toyota
