4AGE 20V BT with Greddy Emanage
E6XLancer
1 Malaysia
Does anybody here have install Emanage to their beloved 20V BT specially on auto tranny...whats the power different with before its...:smokin:
i believed alot member here was using blue box on their BT but mostly is manual.. auto shud have also ..
power differ not comment---
but confirm save FC
actually if u install the emanage blue it is better to tune it wideband of coz the FC is more safe but u also can feel different after the setup .but if u want more power make sure ur exhaust 2.3" if not wont make any different....if wanna install u can call this guy make an appoinment for install a emanage Ryzal=0122800058.this is the guy do wideband tuning on the road and he is good in emange tuning.mine just tune by him -4agze in st150,FC-0.17/km
check back against your modding plan...
you could save $$$...
btw, i'm letting go of my em-blue...
nuff said...:biggrin:
E-manage Blue will definitely bring some gains to your 20v. If no gains, probably there's something wrong with your tuner, the engine or your OEM ECU. However, MT will have better gains compared to AT. On AT, you will have better driveability and it will make your 20V AT more responsive especially on the lower revs. Proper tuning on 20v AT will give you atleast 5whp gain and more if you have proper IHE setup. But then again, I would rather have it tuner for better responsiveness than top end HP for AT.
I'd suggest you to seek an experienced tuner for this and strongly recommend you to look for Ryzzal (as mentioned above).
How about if i change my 4age 20v bt ecu to e-manage blue did it make a lot of different to my hp????????
sorry im stilll new with racing performance hehehehe,i have change my lining n cover clutch with works racing clutch but i cant shift my gear in high rev why did this happen can you help ?????? sorry i dont very fluent in english can you explain in malay language:biggrin:
Sekarang cerita pasal e-manage.
Kena bukak topic baru kat depan kalau nak cite pasal cite lain...
Penyelesaian untuk masalah awak= buang clutch WORKS tu, beli original clutch Toyota 4AGE, atau brand Exedy. Lebih elok quality dari WORKS
I have a ques here. If your BT has the emanage, and one day u cabut the car battery. Then your ECU will reset. When you put it back and run it, the ECU parameters will be slightly different right? won't that affect the overall settings as the e-manage is set to previous ECU settings (before the batt is cabut)? In other words, the air fuel ratio mixture will be affected. Correct me if i'm wrong...
