Car Brands
Car Manufacturers
Toyota
4age 20v BT knocking
<blockquote data-quote="tengko" data-source="post: 1064579238" data-attributes="member: 65846"><p>I having same problem knocking. This happen after top overhaul change piston ring and bearing conrod. Im using trd metal gasked 0.8mm. Distributor cant set more than 10 degree. If I set 10 degree knocking will occur. Any sifu can help</p></blockquote><p></p>
[QUOTE="tengko, post: 1064579238, member: 65846"] I having same problem knocking. This happen after top overhaul change piston ring and bearing conrod. Im using trd metal gasked 0.8mm. Distributor cant set more than 10 degree. If I set 10 degree knocking will occur. Any sifu can help [/QUOTE]
BMW Zagato Coupe - Simply Curvaceous!
Unveiled at the shores of Lake Como in northern Italy, the stylishly
Italianized
Z4 roadster had its sheets...
Members:beware of this fairlady
In case of any of the members here shopping around for a fairlady pls beware of the car...follow the link below..
http://www.zerotohundred.com/newforums/cars-for-sale/276507-nissan-350z-st-manual.html#post3542033
Looking for ori evo456 ic piping
Hi
Looking only right hand side ic piping.Ori piping after ic that goes into throttle body.Need only front...anyone wanna sell it...thanks
Car Brands
Car Manufacturers
Toyota
