Car Brands
Car Manufacturers
Toyota
20v exhaust question
<blockquote data-quote="7Heaven" data-source="post: 3062868" data-attributes="member: 13962"><p>small small project? wat projext wei!<img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/biggrin.gif" class="smilie" loading="lazy" alt=":biggrin:" title="Biggrin :biggrin:" data-shortname=":biggrin:" /></p></blockquote><p></p>
[QUOTE="7Heaven, post: 3062868, member: 13962"] small small project? wat projext wei!:biggrin: [/QUOTE]
david tao
WTB GTR dashboard monitor
i m driving a V-Spec, but my monitor start to mulfunction now. i m looking for a replacement, but i do not feel like put DEFI in as i drive around KL much and feel unsafe to use DEFI.
any idea where to get a...
Stock ecu + safc + s-itc = result ?
ok 1st of all we know that when we use fuel piggyback such as safc and fools the ecu with false signal, automatically ignition map will be screwed
now i want to know, can we 'fix' that screwed ignition map using...
DIY wideband monitoring device
You guys like to diy things?
Look here:
http://www.aces.edu/~gparmer/efi/temp/wb/guide.html#circuit%20board
You can monitor the output using a cheap digital voltmeter.
Car Brands
Car Manufacturers
Toyota
