Main Forums
Car Talk
Car Modification
1.5 Lancer MX B.O.T...
<blockquote data-quote="SkYwAlKeR" data-source="post: 3385223" data-attributes="member: 10341"><p>bolt on turbo kit can be custom/rojak from other makes.... all u need is turbine (td04 sufficient), intercooler (gsr one ok adi... mau bagus lagi vr4 ic), aftermarket bov, custom intercooler pipings, piggyback ecu... u'll need to do custom exhaust manifold....</p><p></p><p>u may want/need other enhancement such as fuel pressure regulator, larger fuel pump, larger fuel injector, bigger throttle body, etc...</p></blockquote><p></p>
[QUOTE="SkYwAlKeR, post: 3385223, member: 10341"] bolt on turbo kit can be custom/rojak from other makes.... all u need is turbine (td04 sufficient), intercooler (gsr one ok adi... mau bagus lagi vr4 ic), aftermarket bov, custom intercooler pipings, piggyback ecu... u'll need to do custom exhaust manifold.... u may want/need other enhancement such as fuel pressure regulator, larger fuel pump, larger fuel injector, bigger throttle body, etc... [/QUOTE]
david tao
First Impression: 2011 VW Polo GTI
Where does the Polo GTI fit in the world of competitive hot hatches? A modern day hot hatch is practically a scaled down performance car with all the essentials of a family commuter. The latest Polo GTI excels in...
rays rim for evo 456789
used 17 inch rays grams light 57 pro for evo
type:casting 2 piece
pcd:114.3
5 holes
wide:8jj
offset 31
good condition,no dent
tyres no more thread
sprayed to white
original colour=gold spoke and chrome...
Check out his car
What car would the wheel designer of all the ADVAN wheels potter about in?
http://www.superstreetonline.com/featuredvehicles/130_0310_rx7/
Cheers
Main Forums
Car Talk
Car Modification
